550 firing order
Greg Whittaker
07-22-2003 18:07:35
I need to know the firing order on a 550 Oliver engine. Actually it's a 552 forklift. I don't see it cast into the engine anywhere. Also which tower on the cap is number one? It's a Delco Remy distributor if it makes any difference. I was in need of the distributor cap in a hurry and pulled it off without paying much attention figuring that the firing order was cast into the engine somewhere. I went to put it back together tonight and nothing. Thanks, Greg W.
Craig Phillips
05-16-2004 19:10:16
 Re: 550 firing order in reply to Greg Whittaker, 07-22-2003 18:07:35
I am in need of a cap and rotor and points for a White FL44 forklift (same as Oliver 552). I am having trouble cross referencing and getting the parts. Do you have any recent part number that may help me out?
J. Schwiebert
07-22-2003 18:17:03
Firing order 1-2-4-3. Always remember the two cylinders across from each other on an inline engine with an even number of cylinders add up to one more than the number of cylinders in the engine. Distributor rotates clockwise and number one should be at the front toward the block. Take number one plug out and check for compression and see where rotor is.
