Row Crop 60 engine manufacturers
Mark
07-19-2003 20:38:19
Folks,
we have a 1946 RC 60 that was bought new by my uncle, right after the war. It has a Continental engine. I saw another RC 60 from about the same vintage and it has an Oliver engine..or so it says.
How many different engine makers supplied engines for these tractors? What is the horsepower for the 4 cylinder Continental engine?
jocco
07-21-2003 04:11:34
 Re: Row Crop 60 engine manufacturers in reply to Mark, 07-19-2003 20:38:19
dont rule out that some one did this "at home " after warrenty exspired i have seen many tractor with other engines some were professionly done some were crued
Terry
07-20-2003 15:32:06
All production Oliver 60s had a Waukesha designed, Oliver built 4 cylinder engine. If you have one that is an original engine, with a Continental, it must be some experimental model. I own and have seen a lot of 60s, and all of the ones I have seen have the Waukesha/Oliver engines.
It would be interesting to find out the story behind yours. Terry.
Mark
07-20-2003 16:31:27
 Re: Re: Row Crop 60 engine manufacturers in reply to Terry, 07-20-2003 15:32:06
well Terry, they made at least one without a Waukasha engine in it anyway!
My uncle is dead, the tractor was bought 12 years before I was born ('58) and all that remains is the physical evidence of the machine itself. It really doesn't matter to me who made the engine.....in my ignorance I figured the Continental was a common engine for the 60. I was visiting a friend who had a junked 60 sitting near his barn and on examination, seen that it had an Oliver engine. I recall (about 10 years ago) asking him about the Continental connection then, but he didn't know either.
This is a real can of worms and i'll try to find out what the spec. plate says on the engine block and let you fellows dig deeper.
ajax implement
07-20-2003 16:39:57
 Re: Re: Re: Row Crop 60 engine manufacturers in reply to Mark, 07-20-2003 16:31:27
Just thinking about this, there are so many changes that would to be made for the Continental.
I have worked on a few 48 models that were a little different. It almost was like Oliver ordered X number of engines and they had orders for X+Y tractors. So Waukesha had to use some items they had not planned on. But they all had the 160 Waukesha in them.
ajax implement
07-20-2003 11:13:56
No I was not trying to be the smart one. Since the serial number for the model 60 was on a plate on the engine what is the serial number for this one? What model Continental is this? According to Bob Tallman in one of the newsletter they did some expermenting with different engines after the war and before the Fleetline series were introduced. I used to have a picture of a sixty with a diesel in it taken in Charles City. It also has a different gearshift handle. I would like some more details.
Mark
07-20-2003 11:31:25
 Re: Re: Row Crop 60 engine manufacturers in reply to ajax implement, 07-20-2003 11:13:56
I'll try to get down to dad's and take a closer look and post what I find. The tracor still has it's original firestone tires! It was neglected more than used, probably has less than 1,000 hours on it. I recall it being used to 'drive' shallow water wells when I was a kid (early 60's). They had this pipe derrick with a wooden pile driver hooked to a rope that was in turn, wrapped around the pulley wheel on the Oliver. When the rope was pulled, it tightened on the pulley and lifted the driver..... release the tension on the rope and the driver fell, driving the water pipe(attached to a well point) in the ground. I thought it was a pretty neat trick. I also saw this method used by jacking a car up and a doubled rear wheel/rim used as a pulley.
The RC 60 was bought new in 1946, along with a set of pull type plows, a drag disk, and a JD sicklebar mower. I watched my uncle get wound up on the mower PTO, damn near took his leg off...actually tore his right calf muscle from the bone. I can vividly recall the sound of his overall gallus buttons snapping off as the PTO wound his britches legs up. Not nice.
havvey
07-20-2003 09:01:30
JUST AS AN ASSIDE I HAVE HEARD OF SOME 70 S WITH OTHER ENGINES I KNOW ALLIS AND FARMALL DID THE SAME
ajax implement
07-20-2003 04:27:46
All Oliver 60's have a Waukesha/Oliver engine. The Oliver 70's had the Continental engine and it was a six cylinder overhead valve D model engine.
Mark
07-20-2003 06:53:00
 Re: Re: Row Crop 60 engine manufacturers in reply to ajax implement, 07-20-2003 04:27:46
well..... ..would you like to place a wager on that? he-he, not being a smartaleck, but I KNOW this is the original engine and it plainly says on the side CONTINENTAL.
My 70 year old father tore the engine down a few years back and has yet to put it back together, it's all down at his place.....if it was here I'd copy all the info off the spec. plate and post it here.
I THINK that perhaps right after the war, outside suppliers like Continental may have been tapped until in house production was re-established???
