Servicing the transmission and rear end
Jeff in Indy
07-16-2003 06:54:42
I have an Oliver 1800 and I want to service/check the transmission and rear end lubes. I have an IT shop manual but either I'm blind and can't read or they've ommitted a chapter on general servicing (or hey.. maybe it's both). Anyway, I believe the fill points are on the left side of the tractor just below the operator platform adjacent to one another. Is this right? I'm assuming both take 80w-90w. Do you fill to the lip of these plugs or is there a plug you pull and fill until if overflows from?
Thanks for your help.
Ollie
07-16-2003 07:16:07
 Re: Servicing the transmission and rear end in reply to Jeff in Indy, 07-16-2003 06:54:42
The information you need is in the operator's manual, available for purchase on this site. It has pictures of everything. There's more to it than you may be aware of.
Myron KY
07-16-2003 08:10:07
 Re: Re: Servicing the transmission and rear end in reply to Ollie, 07-16-2003 07:16:07
Ollie's correct on the Owner's manual. Your not blind either. The I&T does not cover general maintenance. While your at it, I strongly suggest you obtain the Oliver Service and Part manuals. The Oliver and I&T service manuals compliment each other well. Where one is vague the other is more descriptive. At least on the 1850 they are.
Here is another place to get manuals, if you have problems getting them here.
Floyd County Museum
Good Luck!!!
Myron KY
Ollie
07-16-2003 08:41:18
 Re: Re: Re: Servicing the transmission and rear en in reply to Myron KY, 07-16-2003 08:10:07
Myron, as always, your are right. I can't imagine how anyone would actually work on a 4 digit Oliver without all 4 manuals. The 3 Oliver manuals are mandatory and the IT manual, as you pointed out compliments the Oliver service manual nicely and is the only one I've found with correct wiring diagrams.
Jeff in Indy
07-16-2003 11:07:58
 Re: Re: Re: Re: Servicing the transmission and rea in reply to Ollie, 07-16-2003 08:41:18
Thanks guys, I honestly never thought to check this site for the manuals. I'll have to get one. I would still like to know how to check these properly in the mean time. I'm planning to go bale up a few acres of straw and don't really want to be running the tractor several miles from home and encounter any problems.
Myron KY
07-16-2003 12:23:01
 Re: Re: Re: Re: Re: Servicing the transmission and in reply to Jeff in Indy, 07-16-2003 11:07:58
Is your 1800 an A, B or C series? I believe there were some transmission changes between the series that would effect the fill and check point locations.
Jeff in Indy
07-16-2003 14:57:55
 Re: Re: Re: Re: Re: Re: Servicing the transmission in reply to Myron KY, 07-16-2003 12:23:01
Mine is a series B s/n starts with 125 I think.
Myron KY
07-17-2003 11:15:11
 Re: Re: Re: Re: Re: Re: Re: Servicing the transmis in reply to Jeff in Indy, 07-16-2003 14:57:55
Jeff, you might also try asking on these sites.
Larry Harson's site
The Oliver Gang
HPOCA
It looks like the HPOCA site is down right now though.
Hopefully you get an answer here or from those sites. Good Luck!!!!
