Oliver engines
kevin
07-15-2003 07:17:18
I need some help! Besides an 3208 what was the biggest cubic inch motor olivers put in their tractors? Was it the 478 herc?
Thanks
For the help.
Gary
07-15-2003 15:34:44
 Re: oliver engines in reply to kevin, 07-15-2003 07:17:18
Hart Parr 30-60 10" bore 15" stroke 2 cyl figures out to a little over 2000 CI.
Shep Va
07-15-2003 08:41:44
The 478 Hurk was a very big engine used in the 2050 and 2150 Olivers. Oliver also used the 3208 636ci and the 3150 573ci V-8 Cat engines in the 2255. Also the 2455 and 2655 Oliver tractors used the big Moline 585ci engine. Those were the biggest of the Olivers. The Moline engines went bigger though, the 585 Moline engine ran in lots of the later model Moline tractors and I think it had an option in the G-1355 Moline / Oliver tractor for the 800ci Moline engine.
So if you had a G-1355 painted Green with the Oliver logos, and it had a factory replacement Moline 800ci engine, that would be the biggest ci Oliver engine in a tractor. Dont know if that exists though.
David
07-15-2003 12:40:00
 Re: Re: oliver engines in reply to Shep Va, 07-15-2003 08:41:44
I've seen a couple of 2655 propane's around that have the MM 800HD in them. If I'm correct, I saw that Hull's in Wisconsin had one for sale a couple of years ago. So that would be the largest engine in an Oliver (that's really a Moline).
Bob
07-17-2003 19:29:06
 Re: Re: Re: oliver engines in reply to David , 07-15-2003 12:40:00
The OC 18 had a DFXE Hercules at 895ci.
