880 questions
Dwain
07-13-2003 16:12:57
I am about to attempt to fix an 880 that jumps out of 5th and 6th gear when going down hills. Someone told me that it was probably worn shifting forks. How hard are they to replace and how would I go about replacing them? I found a whole 880 rear end and final drive that I could get parts off of it for cheap. It has a 3 point on it and I thought about just swapping out the whole thing because the man wants $350 for it. I don't really need a three point and I would like to go with the easiest thing to get it working right. Which do you think would be the easiest?
Ron
07-22-2003 18:34:15
 Re: 880 questions in reply to Dwain, 07-13-2003 16:12:57
YOu should consider also the shift collar between gears, I have been down this road in the past and ened up in there a 2nd time cause i did not look at the shift collars the first time around.
I should know, I run a repair shop
oleblu
07-13-2003 17:38:42
I might be interested in the 3 pt hitch if you are going to sell it and are fairly close. Drop me an e-mail. Jim T
havvey
07-13-2003 17:08:17
pull the slides keep the other as a spare
