Don-WI
07-06-2003 10:35:29
Re: Baler tractor in reply to HoyBoy, 07-06-2003 05:51:12
I guess I'll weigh in on this too. I also own a 1600 gas, which I am currently working on(or lack there of) getting it an over-bored engine kit, new paint and new rubber all the way around, including all belts, hoses, etc. My dad always used that on our baler before he bought our Massey 285 a few years later, and since then that has been our maiun baler tarctor, unless it was out of commision. about 4-5 years ago our 1600 was the only other tractor to use on the baler when our 285 was out with a flat rear tire after finding a hay hook out in the feild that's been missing for YEARS. Our 1600 was extremely tired that far back as well, but still had enough power to run the baler at a good speed. Once I am done working on my 1600, I will probably try it on the baler again. It worked great when it was all we had, and I wouldn't mind doing it again. I agree thast the 1600-55's are the best for the job, but a 1550-55 might not be too bad either. Once we tried our 1755 on the baler, just didn't like it because the engine had to be running full throttle to have the right rpm's. But as mentioned before, not only hp, but WEIGHT. If you got a full load and a small tractor, good luck stopping. JD's are just too light in my book, and both my Massey's and my Ollie's are of good weight for their hp. Donovan from Wisconsin
