1755
TP
07-04-2003 10:15:03
Posted about a month ago about hyd problem thanks for your input. Still dealing on the 1755D wf o/u 80%+ rubber good paint and sheet metal ,has rebuilt starter . BAD POINTS;; hyd sometimes fails so no steering or 3pt lift also no brakes then will start working again this is according to the present owner. also has a leak in fuel tank seam .whats it worth ? He ask me 3500 fellow has REDIHC in his blood he don't know if ever any motor work done tractor has about 6000 hrs.So far I have not heard it run. He says it runs great except for hyd problem.
Wade
07-06-2003 18:56:06
 Re: 1755 in reply to TP, 07-04-2003 10:15:03
First of all, I can always remember whether an engine has been worked on ANY tractor that I have ever owned. I may not remember exactly "when", but I don't forget altogether. I would wait to hear the machine run prior to trading my money for it. I have a 1755. It's a dandy tractor, but your 6,000 hour opportunity reflects plenty of work hours completed - for any tractor. Good luck.
TP
07-09-2003 18:56:38
 Re: Re: 1755 in reply to Wade, 07-06-2003 18:56:06
WADE Thanks for the tip .The reason the fellow didn"t know about any engine work was he bought it 3 yrs ago at a dealer without even asking any questions and never cared for good green machinery TP
1755
07-04-2003 20:02:50
I had the same problem with my 1655 hydraulics. The problem was 1) water in the reservoir. Created bubbles and air in line. 2) The relief valve had dirt and was bad. The valve is very sensitive to dirt. As a result, I had intermittent 3 point, and ps. Drained hydraulic oil sveral times, and put in new relief valve, tractor has been good sense.
