1755 Fuel Pump
Aug
07-01-2003 18:52:11
I saw a late 1755 with no fuel transfer pump on the side of the engine. It had what appeared to be a factory cover bolted over the hole where the pump should have been. I recently bought a 1750 at an auction and it also does not have the pump on the side. Has anyone seen other Oliver engines without a fuel transfer pump?
Sam M
07-02-2003 13:10:27
 Re: 1755 Fuel Pump in reply to Aug, 07-01-2003 18:52:11
I have an 1855 and a 1555 with no diesel transfer pumps. In both cases , the pump was removed by the prior owner and the diesel fuel supply is gravity feed from the tank to the fuel filter . Never had a problem with mine . I have a friend with a 1650 and a 1655 and neither have fuel transfer pumps for diesel engine .
Larry from MD
07-02-2003 08:47:03
yes
Don-WI
07-01-2003 20:07:58
Are you talking about deisel, or gas? You never mentioned.
Donovan from Wisconsin
