1650 distributer
larry
07-01-2003 07:51:12
I have a 1650 the points move up and down and the cam is worn in a pyramid shaped outside of sending it down the road what ideas can i try used ,new, rebuilt and would there be a place close to dubuque ia ? how hard are they to replace thanks
Mr Bricole
07-01-2003 09:25:04
 Re: 1650 distributer in reply to larry, 07-01-2003 07:51:12
If your distributor is so expensive to rebuilt or if its hard to find replacement parts, maybe you should look for an electronic ignition upgrade. No matter if the shaft is moving, the magnetic pick up will do the job. Go to Pertronix.com and check it out.
If your distributor model # is not listed, call them and ask, they will find it for you. I did on our Super 55 and it works great!
Ollie
07-01-2003 08:08:55
It all depends. If it's a Holley you're screwed. No parts are available and therefore no one rebuilds them. AGCO will sell you a replacement made by Mallory for $350.
If it's a Delco, any NAPA store will have a rebuilt. You must have the tag # to match it up.
