Oil weight in 770 rear end
dave in Mn
06-30-2003 19:55:38
what weight of oil should I put in the rear end? How many quarts will it take and how would you recommend I flush it out?
Appreciate your help with this matter.
Dave
LARRY
07-02-2003 14:15:32
 Re: Oil weight in 770 rear end in reply to dave in Mn, 06-30-2003 19:55:38
Thanx for pointing that out John, guess I'll go out now and change the oil!!! Larry
J. Schwiebert
07-03-2003 08:51:12
 Re: Re: Oil weight in 770 rear end in reply to LARRY, 07-02-2003 14:15:32
Larry: I do not know if I would rush right into the oil change. What do you do with your 770? Think about all the tractors that have leaking hydraulic pump seals and a rear end full of thin oil.
Does your 770 have the optional Power booster? That was the main reason for the thin oil.
Go to the Hart/Parr site and send me a U2U and I will explain it.
John Schwiebert
07-01-2003 14:13:06
This is for Larry. You read the manual correctly. Then it also said to mix in the 102 something power booster additive. The theory behind this was use the thin oil for the sprag clutch in the power booster. As 80/90 became a more popular oil thye got away from the 30 weight.
J. Schwiebert
07-01-2003 03:43:04
19 quart. 80/90 gear oil will work fine, Before you drain it completely drain about 1/2 out , put some diesel fuel in (couple of gallon)and drive it up and down the road for about a mile and then drain it. Two drain plugs. One for final drive, one for transmission. Check plug is on right side. Questions?
Larry
07-01-2003 11:49:13
 Re: Re: Oil weight in 770 rear end in reply to J. Schwiebert, 07-01-2003 03:43:04
HMMMM, my operators manual says to fill everything with 10-30 oil...finals, trans, pto and belt, for the 770. My 70 and 77 manual calls for 80-90 oil in the trans.
dave in Mn
07-01-2003 08:41:27
thanks for your help!
This board is a great resource!!
