White 2-60 thru 2-85
Mark
06-30-2003 07:06:11
I know this isn't the wanted page but I'm just asking off hand. I'm looking for a White 2-60 thru 2-85 diesel with a narrow front end in any condition. I greatly prefer late 70s. The only stipulation is the narrow front end. It can have fire damage or anything else, blown motor, shelled tranny, etc. It must be withing 300 miles of Cedar Rapids, IA. Let me know if you know of some on dealers lots or private. Thanks, Mark
DuaneWKKC
07-03-2003 04:50:55
 Re: White 2-60 thru 2-85 in reply to Mark, 06-30-2003 07:06:11
I saw a White 2-70 narrow front at tri greens equipment in London Oh. looked like a very early model as frame had some green paint under the silver. Was actually a nice looking setup, but tractor looked pretty well worn. They do exist.
Duane.
Merlin in Saint Paul
06-30-2003 20:18:42
Hi, Mark! Back in late 1996, I re-powered an early model White 2-105 with a turbocharged, aftercooled 6B Cummins. After the re-power was done, I installed a narrow front end off of an 1850. It fit perfectly, and looked great. The reason for this front end change was to mount a Vee plow for moving snow. The tractor is near Saint Charles, MN. It is an awesome machine! Best regards, Merlin
Dsl
06-30-2003 12:08:04
Definitely not practical to convert a White 2-60 to narrow front, as they are a low slung utility tractor, and having the front tires underneath would jack the front end way up. Even switching to 38" rears might not be enough to level it, and you'd have to change the fenders to allow clearance for such large diameter tires.
As for the 2-70 & 2-85, well, by the time they were built, narrow fronts were history, not modern agriculture. You can probably make a 50 series narrow front end work, but it will be work to make it so.
I've never even seen a 55 series narrow front, much less a White, although it would probably look cool. Follow up your endevour with some pics, will ya?
Shep VA
06-30-2003 14:08:16
 Re: Re: White 2-60 thru 2-85 in reply to Dsl, 06-30-2003 12:08:04
Now DSL, you have seen 1655 Olivers with narrow fronts. I have one actually a 1973 model, probably the last years that they put narrow fronts on. I cant say I have ever seen a 1855 with a narrow front but I did see a 1955 narrow front once, I think maybe he put it on though.
I think by the time the whites came out that was the end of the narrow front tractors, but I dont see why you couldnt put one on a 2-85 or a 2-105 maybe. The steering unit in the front should be the same and you could get a larger 50 series front end off an 1850 or so and make it fit I would think. That would be a fun project to try.
Let us know how you make out.
j meyer
06-30-2003 10:45:44
Did they even make these tractors with factory narrow front? I have never heard of one, and I'd think you can paint and put an Oliver one on there if you want one on there. I guess I havent seen a White with a narrow front.
Mark
06-30-2003 12:49:43
 Re: Re: White 2-60 thru 2-85 in reply to j meyer, 06-30-2003 10:45:44
A narrow front was an option on the smaller 2-series tractors early on. I've only seen 2 of these in my life and they probably were more on the size of the 2-70 or 2-75 that I saw. It's been a while but from what I remember they looked alright. I'm looking for my next restoration project and something a little different so if I can get a hold of one I'd be happy. These will be hard to find but not impossible. I know I've seen some on the 55 series Olivers more often but still on these they were getting harder to find as row crop tractors were going out of functionality.
