Oliver/Cockshutt 550 identification
Doug
06-28-2003 05:00:15
I have a Cockshutt painted Oliver 550 (maybe Industrial) with serial number 186-588-019. This number does not match up with any research on serial numbers on this or other sites. The model # is 65-21044 and the plate also has "Cockshutt Farm Equipment of Canada Limited, Brantford Ontario".
I was under the impression that it was built in 1965 but that may be wrong ( it has a fiberglass checkerboard grill). In doing an engine overhaul, we found that the crank was oversized, possibly indicating an Industrial engine.
Any help would be greatly appreciated.
rem
06-28-2003 11:54:28
 Re: Oliver/Cockshutt 550 identification in reply to Doug, 06-28-2003 05:00:15
Cockshutt 550's were made in Canada at Brandford from 1958-1961. They were high profile and had a 4 cylinder hercules gas or diesel.The serial numbers are stamped in the right side top edge of the tub holding the engine. A limited number had diesels. The oliver 550 is a low profile to the best of my knowledge.
Trevor
06-30-2003 07:31:42
 Re: Re: Oliver/Cockshutt 550 identification in reply to rem, 06-28-2003 11:54:28
There were 2 different Cockshutt 550s rem. There was the large 550 that you are referring to that followed the 500 series Cockshutts (540, 550, 560, & 570) and there was a low (utility) 550 that was an Oliver 550 just painted with Cockshutt colour (cream and red belly).
I was told at one time that this was only done for a couple years but I think that is wrong.
I had the opportunity to buy one of htese tractors but as is usually my story I was to short on money when the oportunity arose and to late when I had the money.
Frank Dodson
06-28-2003 08:02:19
I may be totally off base but Oliver made the Cockshutt 550. I do not know it the serial numbers run with the Olivers but the serial number you gave falls in the 1967 class.(186-165 through 193-085. The last number 019 because it has to do with the transmission and it is my understanding that this is not too common. I have an Oliver 550 Special that was sold in Canada and it is a 1964 model with model 552-103 and serial 149805-019.
I hope I have given you correct information and if I haven't maybe some of my Oliver friends will set the matter straight.
Doug
06-29-2003 06:29:10
 Re: Re: Oliver/Cockshutt 550 identification in reply to Frank Dodson, 06-28-2003 08:02:19
Thanks for explaining the "019" of my serial number as this now makes sense why my serial numbers were not consistent with published data. In response to ajax, I believe the crank was 1250 over the expected 2.25"
ajax implement
06-28-2003 13:45:55
I am cuious to know what your crank measured. Standard crank is 2.250 mains, 2.250 crankpins for the rods.The engine was a joint venture between Oliver and Waukesha.
