Oliver super 55 three point pump
Russ
06-27-2003 21:11:02
does anyone have or know where i might find a pump for a 55, i bought one and it must of had water in it , the pump housing broke,
ajax implement
06-28-2003 04:19:12
 Re: oliver super 55 three point pump in reply to Russ, 06-27-2003 21:11:02
Make sure you check the width of the center section. A lot of Super 55 pumps were updated to the later 550 Pumps which gave them a little more flow. It is a V-10 Vickers pump
ROCKY
08-08-2003 23:55:38
 Re: Re: oliver super 55 three point pump in reply to ajax implement, 06-28-2003 04:19:12
IF YOU WANT ANEW PUMP TRY TOUR ADCO OR WHITE DEALER 1200.00 SHOULD DO THE TRICK OR CALL BARRICKS NEWVILLE PA. 1 717-776-5762
