88 oil pressure
David Hunt
06-25-2003 20:49:01
I have an 88 tractor that has low to no oil pressure, runs great no knocks any ideas on where to start?pressure relief valve? oil pump? any ideas would be greatly appreciated.I havent tore into any olivers so i just wanted to know if there was any tricks or common problems with them. thanx
David hunt
06-26-2003 17:39:58
 Re: 88 oil pressure in reply to David Hunt, 06-25-2003 20:49:01
I found the problem!!! The pressure relief valve was stuck and plus the gauge was also bad. thanx much for everyones help. sincerly Dave
Jim F.
06-26-2003 12:06:45
The 88's had low pressure right out of the show room floor. You should probably have about 12-18 psi high idle warm and around 5-10 psi idleing warm.
Larry from MD
06-26-2003 09:01:59
The first place to look is the oil filter base,The restricter under the tube often gets lost out causeing too much oil to go through the filter.
David hunt
06-26-2003 11:51:31
 Re: Re: 88 oil pressure in reply to Larry from MD, 06-26-2003 09:01:59
thanx larry, where exactly is this restrictor located?Under the filter? what does it consist of? thanx Much Dave
ajax implement
06-26-2003 14:23:22
 Re: Re: Re: 88 oil pressure in reply to David hunt, 06-26-2003 11:51:31
The restrictor disk is in the filter base. It is under the tube (stem) that goes into the filter itelf. See if you have an aluminum or a replacement cast iron filter base. This problem is more common on the aluminum bases. Wiggle the stem and pull up on it. If it moves that is the first thing to check. Pull a reliable gauge on it with numbers and see what pressure you have.
