Oliver 1550 Hot Operation
Michael Deslipp
06-25-2003 06:27:52
My Oliver 1550 runs great when cold. As it warms up, it suddenly starts shutting down with the engine surging and surging and then dying. Adding almost full choke brings it up to running speed again, and then running extrememly rich, I can keep it going, however, with a substantial loss of power, poor fuel usage and a lot of smoke.
What would cause the engine to stop running when hot? (typically 30-45 minutes use)
Ollie
06-25-2003 07:05:34
 Re: Oliver 1550 Hot Operation in reply to Michael Deslippe, 06-25-2003 06:27:52
Next time it happens, immediately remove the gas cap. If the engine then runs normally, the vent in the cap is plugged, clean or replace it. If not, replace the ignition coil. As they die, they tend to produce little if any current when hot but will often function perfectly when cold. If it ends up being the coil, I'd at least check the points for gap and condition as a failing coil is very hard on points.
Michael P. Deslippe
06-28-2003 17:33:34
 Re: Re: Oliver 1550 Hot Operation in reply to Ollie, 06-25-2003 07:05:34
Well, I think that may have been the problem. I haven't been able to get it overly hot since you gave me this tip (I'm working hard on an 8N at the moment). How would you go about cleaning out the fuel cap - or is there a source for fuel caps?
Ollie
06-29-2003 03:05:56
 Re: Re: Re: Oliver 1550 Hot Operation in reply to Michael P. Deslippe, 06-28-2003 17:33:34
AGCO dealer will sell you a new one but make sure it is a vented cap.
Mike (WA)
06-25-2003 08:35:53
I would suspect a fuel delivery problem rather than coil- if coil quits when hot, it usually quits completely, and the rig won't run for love or money until it cools off.
mm
06-27-2003 13:09:20
 Re: Re: Re: Oliver 1550 Hot Operation in reply to Mike (WA), 06-25-2003 08:35:53
Maybe it time for a value job Do you hear any ticking noise
