Power from 77
Jay
06-23-2003 19:04:40
Looking to get more power from my 77 gas for pulling. Can any body offer up suggestions. Thanks, Jay
kj
06-27-2003 15:09:37
 Re: power from 77 in reply to Jay, 06-23-2003 19:04:40
i got a 1949 77,she dynod 32 horse when we got it,then we got the head milled the same as a super,and dynod 52.kinda weird?
Keddano
06-24-2003 22:12:10
third party image
Hope this helps,WFE help lead the way for me on this.I took my head and shaved it .125,then my local shop stuffed chevy small block S.S. necked down intake valves into it.(Had to hog the half flat in the head to clear them)porting was also done. The intake valves are stock dia. the exhaust valves had to be ground down. I'm getting back my 1650 intake this weekend that I had the two outer runners cut back to fit the 77 block(about 10mm off each one and the runners wil have to get surfaced to match the exhaust manifold)and the 1650 uses the big M.S. carb(There's three sizes of bodys,the 77 uses the smallest)This should make the head earn it's keep after jetting and port match.I havn't been able to do it yet,but from what I've heard and talked to guy's about,the sleeves(3 3/4" bore)from a 88 can be loaded into the 77 and bored to 4" and survive with no problems.The piston combo (chevy)can be worked out with a good shop.My stock rings and piston are shot on my 77 and I still place well in #4000 and #4500 with uncut 15.5 tires(I look like a diesal going down the track this year)Hope this helps,now if I can get back to normal work maybe the lower end will get done
bob
06-24-2003 07:14:08
Years back in tech school done a rebuild on a 77. Got a cheap set of 3 3/4 sleeves and pistons(on clearance from the local dealer) head was warped so it took .035 to clean it up then took another .035 off to increase ( these figures may be off too been sometime since i had it done. WHen i got it together and going had to adjust the dist. to acomodate the higher compression and the preignition nock. But then when we put here on the dino we got 50 hp out of it. No work was done to the manifolds or the head other then grind vavles. A newer bigger manifold and a 770 head with bigger valves will really boost the hp out of them.
WFE
06-23-2003 22:42:38
keddano has done a lot of work on his 77 and has achieved some impressive results. Hopefully, he'll divulge some of his secrets and research. The cheapest way for pretty big hp gains?? More compression! Depending how much you shave the head, you'll have to use higher octane fuel and adjust timing to prevent preignition. Then, probably bigger carb/main jet.
