S77 steering how much play in swheel?
eric
06-22-2003 19:45:55
i got about 3 inches play before it starts to turn. how do i tighten it up? take out the shims that are around the steering rod as it enters the steering box? as always thanks for your time
B A Star
06-24-2003 20:06:34
 Re: s77 steering how much play in swheel? in reply to eric, 06-22-2003 19:45:55
If you have end play in the shaft that goes into the steering housing, yes you can remove shims to eliminate it. Take off the plate on the top of the steering housing, in the grease under the sector gear you will find a support for the upper end of the pedastal shaft, It is an excentric, find the cap screw that locates it and remove, then turn the excentric to eliminate the slack.
