Installing the nylon tees for injector return line
RB
06-18-2003 17:54:09
I have a 1955 with a 310 that has a leaking nylon tee on the no.1 injector. I replaced all of these tees a few years ago and lost most of my religion placing the ring clamps on the tees. I even had one of those special pair of pliers to use. Does anyone have some advice about how to do this job easier? Thanks in advance.
Sam M
06-19-2003 08:45:00
 Re: Installing the nylon tees for injector return in reply to RB, 06-18-2003 17:54:09
I did the same thing on my 1855 that Wrenchbender recommends ( small hose clamps that you can tighten with a nut driver or long screw driver ). I think the whole job for all six injectors takes 18 clamps . I would take one of the Ts to an auto parts store and get clamps that are slightly larger than the outside diameter of the T . You can also remove some of the sheet metal on the tractor which may give you better access although to take the sheet metal on top off you have to remove the muffler and precleaner . I would recommend replacing the Ts on all six injectors at the same time . Once one goes bad they all seem to start going bad and it is easier to replace them all now when the engine and manifold are cool than when a T starts leaking out in the field and everything including you are as hot as fire .
Wrenchbender
06-18-2003 18:48:39
I have put small hose clamps on them. Both on the injector and the pipes in between. Make sure the replacements are the Roosa-Master brand and not some aftermarket cheapies! Been there, done that. The cheap ones came from Tisco and were hard and not pliable. WB.
