770 hydraulic problem
JP
06-16-2003 09:01:29
When I add fluid to the hydraulic system the fluids seem to end up in the transmission/final drive system. Does anyone know whats happening?
G FROM MD
06-16-2003 10:08:17
 Re: 770 hydraulic problem in reply to JP, 06-16-2003 09:01:29
J you hit the nail on the head.
J. Schwiebert
06-16-2003 09:12:07
Yes. There are 4 seals in the hydraulic pump. These seal the fluid in the pump. They need to be replaced. You also should replace the needle bearings at this time. Remember you need to remove the long PTO drive shaft as it is what drives the hydraulic pump. Questions send me a e-mail
