Super 55 trans. problem
Mike
06-14-2003 12:55:02
I cultivated my field the other day with my Super 55, parked it, and when I fired it up the next day wierd stuff happened; with the shift lever in neutral it'll creep along real slow when you let the clutch pedal out. If you put it in any other gear and let the pedal out the motor strains but the wheels act like their locked. Anybody run into this before? I haven't looked in the trans. yet.
J. Schwiebert
06-14-2003 14:24:02
 Re: Super 55 trans. problem in reply to Mike, 06-14-2003 12:55:02
Your problem may or may not be minor. Pop the gear shift handle out (2 capscrews) and look in there with a light. One of your shift rails does not line up. Line it up with a pry bar. IF all 3 are lined up, one of the bushings in one of the gears seized. Remember all the gears turn all the time even in neutral. Questions send me a e-mail
Mike
06-16-2003 15:07:20
 Re: Re: Super 55 trans. problem in reply to J. Schwiebert, 06-14-2003 14:24:02
Well, it was like you said, one of the rails was slid backward. I popped it back into place and things work ok. Do i need to service those two keepers to stop it from happening again, or is that just something that occurs from time to time?
Mike
06-14-2003 16:38:02
Thanks, I'll check it out.
