2255
vern in tx
06-11-2003 23:02:11
any one know why the 3150 was dropped and the 3208 was used in the 2255's.did cat just stop making the 3150
Mike
06-12-2003 19:36:41
 Re: 2255 in reply to vern in tx, 06-11-2003 23:02:11
Cat stopped making the 3150 and also a smaller version used in Ford trucks. Most of the volume was in the 3160 size. When Cat replaced the 3160 with the 3208, they decided it was lower cost to make all the engines the same size and have different fuel pump settings for different power levels. There were versions from 150 HP to 225 HP for one with a turbo. The truck versions tended to be set higher since most vehicles do not run at max power for very long. The settings in ag applications tended to be lower because you can mainain a high load on a tractor, combine, or forage harvester for a high pecentage of the time.
There were a number of improvements made with the introduction of the 3208 to improve reliability.
Larry from MD
06-12-2003 04:49:11
I know there was lots of talk around that time that the cranks where bad on the smaller engine.The local dealer replaced several with the 3208 crank.
