1950T brake problem
gaetan
06-11-2003 18:40:10
I just put new disk in my 1950 T and do not like the way they work no oil in there if I go foward pretty hard to stop go backward
almost power brake brake very good did I put something backwards
John Schwiebert
06-14-2003 08:07:56
 Re: 1950T brake problem in reply to gaetan, 06-11-2003 18:40:10
How many disk did you put in. It takes 6. Were they metalic ones or the fiber ones. How do you have them adjusted? Do your outer covers have shims?
giselessoucy@hot
06-14-2003 17:05:43
 Re: Re: 1950T brake problem in reply to John Schwiebert, 06-14-2003 08:07:56
i would call them metalic but i find the problem the ball where
kind of rusty clean that and litle
bit of grease did the job
J. Schwiebert
06-14-2003 19:25:23
 Re: Re: Re: 1950T brake problem in reply to giselessoucy@hot, 06-14-2003 17:05:43
Graphite works good. If you do a lot of tillage work grease tend to pick up dust and dirt.
Larry from MD
06-12-2003 04:45:39
Did you loosen all three pins(piviot points)on the brakes.You can reverse the metal parts and it will work the same.
