Saginaw Steering Motor
Myron KY
06-10-2003 12:38:17
Does anyone know the, cubic inch / per revolution, displacement of the Saginaw steering motor? I'm trying to match specs. with a Char-Lynn steering motor. This is for an 1850 with the open center system.
Also if anyone has done this before, I sure will appreciate any tips.
Thanks,
Myron KY
Shep Va
06-10-2003 12:51:39
 Re: Saginaw Steering Motor in reply to Myron KY, 06-10-2003 12:38:17
A lot of the later model 1850's had the Char-Lynn system in them, including mine. I would think you could change them pretty easily but I have never done it before. You probably need to get some advice from some of the guys that have messed with the steering motors more than I have. Are you planning on changing the steering motor and the cylinder out front too????
Good luck
Myron KY
06-10-2003 14:10:10
 Re: Re: Saginaw Steering Motor in reply to Shep Va, 06-10-2003 12:51:39
Just the steering motor, as I know it has problems. Most of which I created. (Long story.)
I'm hoping to retain the tilt and telescoping features and have an idea how. I just want to get a motor with enough displacement, so it won't take 25 turns lock to lock.
I may need to borrow your credit card before this is over. :^)
Larry from MD
06-10-2003 16:12:06
 Re: Re: Re: Saginaw Steering Motor in reply to Myron KY, 06-10-2003 14:10:10
I've done 3 of these conversions.About the size the units out of Massy 410 or 510 combines is the correct displacement.Most of those are series 2 valves and are easy to get,you have to make your own steering collum.If you get a series 1 places like surplus center will sometimes have the steering collum to fit it.The flow divider puts 3 to 6 gallons a minite to the valve so stay in that range and 4 to 6 ci per rev.If you can't find a used piviot piece then make your own thats what I did.
Myron Ky
06-11-2003 05:58:58
 Re: Re: Re: Re: Saginaw Steering Motor in reply to Larry from MD, 06-10-2003 16:12:06
Thanks Larry. I found a Series 4 motor rated at 4 gpm and 9.7 ci per rev. Do you think this is too high of a pi per rev rating. It's about the cheapest Char-Lynn I've found so far.
Myron KY
Shep VA
06-11-2003 08:02:55
 Re: Re: Re: Re: Re: Saginaw Steering Motor in reply to Myron Ky, 06-11-2003 05:58:58
Why cant you get one out of an Oliver tractor that is a Char-Lynn and change the entire system behind the dash??? I would think they would have some in a boneyard somewhere and that would be easier, but I have never tried to get one, so I dont know. Enlighten me please!!!!
Myron KY
06-11-2003 14:06:23
 Re: Re: Re: Re: Re: Re: Saginaw Steering Motor in reply to Shep VA, 06-11-2003 08:02:55
Good idea. I was not aware that the late 50 series used Char-Lynn. AGCO does still offer a Char-Lynn conversion kit for around $625.00. I hope to do a conversion allot cheaper than that.
Thanks Myron KY
Larry from MD
06-11-2003 09:08:36
Most of the used tractors have the old style or they have the new char-lin closed center system.If you get a series 1 valve all the other parts from a closed center tractor will fit so the change would be easy.You can allways look for a used one,at anytime a tractor could come in with one.The times that I looked they said they didn't have any.I got one of the series 1 valves from a road roller.As far as size goes it's a big ? because I don't have a size for the ones I used.I can say that all the char-lins steer much easyer than the saginaws.
