Ring and pinion gear for oc 46 crawler
scott m
06-08-2003 14:07:49
Does anyone have a ring and pinion gear for sale for an oliver oc-46 loader, or know where they are availiable? Mine has a few less teeth on it these days. Thanks.
Scott m.
Lionel Charron
06-09-2003 18:36:28
 Re: ring and pinion gear for oc 46 crawler in reply to scott m, 06-08-2003 14:07:49
Scott,
Are the ring gear and pinion gear the same as for the OC-3? If so, I have an extra transmission that needs a reverse idler, reverse idler shaft and reverse idler bearings. The rest is usable, but not perfect.
scott m
06-09-2003 19:06:59
 Re: Re: ring and pinion gear for oc 46 crawler in reply to Lionel Charron, 06-09-2003 18:36:28
I don't know if they are the same, I sure wish I could find out from someone what other crawlers they interchange with if any. If I find something out I will get in contact with you. Thanks.
Frank Dodson
06-08-2003 14:47:51
Try Landis Zimmerman at 717-738-2573.
