77 Throw out bearing
Keddano
06-07-2003 19:48:56
third party image
Put a new throw-out bearing in the 77 puller last year.This year it's making noise.Has anyone ever cut a opening in the bellhousing to lube them before.Rather not have to pull the motor.Thanks
Keddano
06-10-2003 20:58:58
 Re: 77 Throw out bearing in reply to Keddano, 06-07-2003 19:48:56
Thanks for the input,Dan
Larry from MD
06-08-2003 06:56:18
Yes ,but oliver has a greaseable bearing and a hose allong with the right holder that lets you grease from the outside.This kit had to be retrofited on the older tractors.Some tractors came with a larger hole and a zerk right on the bearing.Napa and some other places are trying to sell this bearing instead of the one with the grease hose.
Scott Green
06-08-2003 06:49:50
I've drilled a hole in the bell housing of my brothers Oliver "77". Squirted oil in. It worked.
