White steering problem
tooly
06-04-2003 22:48:00
I need some advice from some of you White tractor fans/mechanics out there.
We have a White 2-135, which has a problem with steering wandering. The tractor will take off to the side , and it may require 1/2 turn of the steering before it begins to respond . Also when standing still usually if u turn the steering wheel slowly, it may or may not move the front wheels.Again , may require 1/2 turn or more before responding. It seems to me a seal is probably bad , allowing oil to bypass.
My question is , Is there any way to identify if this leakage is in the steering cylinder assembly, or in the control ( at the steering column).Has anyone worked on these tractors enough to give an educated guess as to which would be the problem area?
Thanks fellows.
Jim Hockemeyer
07-03-2003 10:20:32
 Re: White steering problem in reply to tooly, 06-04-2003 22:48:00
Tooly,
Did you get the steering problem fixed yet?? We have the same issue with ours. We have totally rebuilt the entire front end and it still does it. I was wondering if your problem was under the dash panel as well. I just talked to a guy a week ago and he just fixed a 2-155 by fixing something under the dash like Larry is talking about. I was unclear on what he really replaced but he stated that it was no fun to replace. Does anyone know how exactly to get to it? Does the whole dash have to come off, side of dash or what?
tooly
06-05-2003 23:24:30
Thanks ever so much , fellows for all the info re. my steering problem.
Will check things out now that seeding is done
B A Star
06-05-2003 13:00:41
The previously posted comments regarding loosness are all good and should be checked. There were some things with the steering system on the 2-135/2-155 tractors that can be improved. One of the problems is in the spindle area. The load of the front of the tractor is carried on a thurst washer between the spindle and the axle housing. There is a grease fitting on the housing, however when greased it all goes to the top and not to the thurst washer area. Unless youi have taken it apart and lubed, it is dry. The 2255 front axle (it is a MM design that was carried over to the Whites) had an antifriction bearing #30-3156761 (Aetna #A 3803). The antifriction bearing was replaced with the thurst washer for the White tdractors. The spindle hangs up between the housing, washer & spindle as most are lacking lubrication, the operator turns the steering wheel more and more and pressure builds up to the point where it finaly lets loose, and the result is oversteer. My brother in law had two 300 gallon fertilizer tanks on the front sides of his 2-155 when he was planting, that really made the problem worse. The steering is quite quick on these tractors. I have modified some of the control units to slow them down. After modification it takes more turns lock to lock, however it reduces the oversteer and gives you finer control. I changed both areas on the brother in law's tractor and he said it steered 100% better,like his old 2255 after mods. If you are concerned about steering cylinder leakage, remove the return hose from the fitting on the top cap of the cylinder. Plug the hose with a 5/16" bolt and run the tractor, you should not get more than drops to a little trickle out of the fitting when engine is running.
jps
06-05-2003 07:36:40
Is the 135 steering anything like the 1855? If so, there is a large nut under cap at the top of steering cylinder.This cap is under radiator. I know on the 1855 if that is loose just a small amount the tractor will waunder. I,m pretty sure 1855& 1850 are somewhat the same. Not sure on 135.That nut really has to be very tight!! Not sure of torque setting. jps
Larry from MD
06-05-2003 04:57:26
Sounds like the check valve in the steering unit under the dash is going bad.The hard part is getting to it. the spring and steel ball are just inside the oil port that returns oil back to the tractor.You have to remove the dash and enough wires to remove the steering valve.This problem will only get worse.Closed center systems are the only ones with this extra check valve.
JLC
06-05-2003 08:14:40
 Re: Re: White steering problem in reply to Larry from MD, 06-05-2003 04:57:26
I agree with Larry. I had the same problem with my 135. The check valve is not easy to get to, but after you replace it your problem should be fixed. It doesn't sound like anything is leaking, if it was you would have fluid all over the platform. JLC
James
03-14-2004 17:27:03
 Re: Re: Re: White steering problem in reply to JLC, 06-05-2003 08:14:40
O.K. I have finally gotten time to tear out the steering unit under the dash to replace the check valve. My question is this to those of you out there to have done this before. I inspected the check valve and it appears to be O.K. in appearance only. Upon further investigation the "O" ring closest to the ball looks very flat? Is it supposed to be a flat "O" ring or a round "O" ring. I also checked out the ball seat and it appears to be O.K. in appearance. What do I need to look for in particular? Do I have the whole steering unit rebuilt or checked out by some professional. We have been a long time waiting a solution for our tractor and when I found this e-mail last summer I was estatic. I want to find a root cause before I just put a new "O" ring or check valve in and put it all back together. Can someone help me out?
Ollie
06-05-2003 03:04:10
Worn front-end parts... wheel bearings, tie rods, ball joints, etc. Jack the front end up and grab a wheel and twist it side to side and you'll see it right away.
