Breakerless distributor for 310 Waukesha?
Jim Meade
06-04-2003 04:44:49
Is there a retrofit which will remove the distributor from the 310 Waukesha? If so, I'd appreciate any information.
Frank
06-04-2003 08:02:20
 Re: Breakerless distributor for 310 Waukesha? in reply to Jim Meade, 06-04-2003 04:44:49
You can also go directly to Pertronix.
The upgrade is easy and the installation drawings are included. I bought one for my Super 55 and it started right away. I already had it converted to a 12V negative gnd with an alternator. I paid 75$ for the ignitor. Pertronix has vemdors all over the place. Check their web site they also have an online catalog.
jake
06-04-2003 06:02:16
Jim; contact genesee they make electronic conversions Give them the distributor number. It can be seen in the "research & info" section", "articles", then "updating electrical system of an Oliver 55. Its fast, easy amd no more points. Good luck Jake
Jim Meade
06-04-2003 14:42:45
 Re: Re: Breakerless distributor for 310 Waukesha? in reply to jake, 06-04-2003 06:02:16
Genesee will make one for me, but it won't have a tach drive. I'm not crazy about that. What can I do about the tach question if not from the distributor?
Ollie
06-04-2003 15:04:35
 Re: Re: Re: Breakerless distributor for 310 Waukes in reply to Jim Meade, 06-04-2003 14:42:45
www.datcon.com makes an electronic tach and also a tach/hourmeter that connect to the negative terminal of the ignition coil. It fits in the same place as your current tach.
Ollie
06-04-2003 06:54:04
I looked into this "kit" for my 1650. They want $200 for it. No thanks. I can buy enough points and condensors to last 10-20 years for $200.
PD
06-07-2003 23:19:59
 Re: Re: Re: Breakerless distributor for 310 Waukes in reply to Ollie, 06-04-2003 06:54:04
Pertronix or anybody else could charge $2000 for their electronic ignition kits, and it would still be a bargain! Go ahead, be cheap. Fool with points that were outdated when the tractor, car, truck, or whatever was built. No thanks. Regards.....P
Ollie
06-08-2003 04:04:43
 Re: Re: Re: Re: Breakerless distributor for 310 Wa in reply to PD, 06-07-2003 23:19:59
I've been "fooling with points" since the '50s. I buy quality parts, install them correctly, and inspect and replace them when necessary, which is every 4-5 years.
It's not about saving money. It's about not pissing it away on something that is not cost-effective.
jake
06-04-2003 11:43:54
The reference to the conversion was to show the ease of conversion. My self I would rather the thing ran fine for 10 yrs instead of waiting till it quit in the field.
