Super 55 Info Needed
Newbarndesign
06-03-2003 10:46:15
I have found a Super 55 for sale ($2500) and I have some questions. What is the HP of that tractor? It comes with a PTO and 3PT hitch but no draw bar. How hard would it be to add a draw bar? I am uncomfortable using a bar between the 3PT arms to pull equipment, Plows, Bailer, Mower,....
The add says it also comes with hydraulics, it is painted yellow. For the most part this is the perfect size tractor for my small farm. Does it sound like a deal? the owner says it all works and starts up right away. It still has the 6volt system though.
Any thoughts would be appreciated
thanks
Phil
Frank Dodson
06-03-2003 12:24:52
 Re: Super 55 Info Needed in reply to Newbarndesign, 06-03-2003 10:46:15
The Super 55 went into production in 1954 and continued until 1958 when it was replaced with the similar 550. The 55 has 34.39 pto hp and 29.6 drawbar hp. It has a 144 cu. in. engine and weighs 3369 lbs. If the tractor is in good shape it is worth $2500. The 55 out classed the Fords of that period.(8N, NAA, 600) The tractor was green except for the industrials which were painted yellow. As for the drawbar, a heavy drawbar(swinging drawbar) was available as optional equipment. You can still find these on internet etc. but they are pricy. I talked to an individual today that has a drawbar that he might sell. He is located in TN and can be reached at Massey Equipment 877-237-9258 or 931-438-7996.
Newbarndesign
06-03-2003 12:31:38
 Re: Re: Super 55 Info Needed in reply to Frank Dodson, 06-03-2003 12:24:52
Wow, Thanks for the quick reply. Well then I guess I will drive out and check it out. Thanks
