WHITE 2-70 remote cylinders
Hal S.
04-22-1999 14:34:26
i have a white 2-70 row crop. I am trying to get a double acting cylinder to work for a rollover plow using the right side remote; so far no luck. The 3-point works ok. When I move the lever for the remote nothing happens, and it stays in the detent position. When it is in the detent position, the 3-point does not respond until i move the remote back to neutral. Is there some adjustment i have to make. i believe the previous owner was using the remote outlets to run hydraulic motors on a harvester conveyor. Thanks.
Pete in Ks
04-23-1999 04:53:52
 Re: WHITE 2-70 remote cylinders in reply to Hal S., 04-22-1999 14:34:26
Check in your manual I believe there is an adjustment for running Hydraulic motors or single action cylinders.
