Oliver 70RC brakes
Keith
05-29-2003 19:00:46
I'm fixing up a 1938 70 RC and the right side brake linings are soaked in oil. I haven't taken the drum itself off yet as I have yet to acquire the hex bar I need to remove the nut, but in looking at the parts book it looks like there are two seals that could be causing this problem. One is a seal on the drum nut itself and the other appears to be the differential bearing seal. Will both of these seals need to be replaced or will simply replacing the drum nut seal be enough to keep oil out of the brake drum. If the other seals needs to be replaced what kind of job is that? Also any suggestions for a source of parts or a suitable substitute for these seals?
havvey
05-31-2003 04:05:07
 Re: Oliver 70RC brakes in reply to Keith, 05-29-2003 19:00:46
save the old seal and try napa or other srore i have not had a problem with them mine is kinda inside the main case
