Ball joint
joe
05-26-2003 09:16:10
I own a 1850d. It appears to me that the front ball joint is bad. How difficult is it to replace and what tools do i need and how do I go about changing? Thank you
WFE
05-27-2003 15:11:23
 Re: ball joint in reply to joe, 05-26-2003 09:16:10
Just did this myself on an 1850. It's difficult to say what wrenches you'll need, because there are 2 or 3 different styles of tie rods in use and they require different tools. Have a standard set of wrenches and 1/2" drive sockets. I would also arrange to have a torch, as more often than not heat will be required to remove the old ball joint from the steering arm (rust). You'll need to heat the area quite hot and hammer the old joint out. Then you can simply reinstall the new tie rod (for the money, you might as well do the whole tie rod as opposed to merely 1/2 of it). Then make sure you adjust it to obtain proper toe-in, which should be 1/4".
