Three point Parts for 1800
Jeff
05-26-2003 08:11:28
I have an Oliver 1800, gas series "B". I bought the tractor complete, runs very well, but it's minus 1 rock shaft arm, both lower links, both connecting links from the lower to the rock shaft arms, and the center link. No information was provided as to why these items were removed. I'm guessing that something is failed internally. Moving the 3 point control lever to the down position and hanging on the remaing arm produces no motion. I cannot pull it to the down position. Any thoughts? I would like to replace the missing parts. The local salvage yard claims to have them but they must be gold plated as they want $500 just for the lower links.
The power steering and hyd lift work fine. I'm under the impression that these are powered by the same pump so I don't think thats the problem. I primarily cut hay and bale with this tractor so 3pt is not something I need. I just want to put it back on the tractor.
Larry from MD
05-26-2003 15:01:29
 Re: Three point Parts for 1800 in reply to Jeff, 05-26-2003 08:11:28
Well the linkage could be broken or the lowering valve could be stuck,or the the 3 pin link could be installed backwards and upsidedown.If you do your own work they are not expencive repairs.
