Numbers on Engine block
Scotty
05-24-2003 20:17:28
Can anyone tell me the year or modle by these casting numbers off the engine block 180220E then under that 1L100B I think the tractor maybe a S-55 Thanks for any help, Scotty
Richard Purdy
08-10-2003 14:27:35
 Re: Numbers on Engine block in reply to Scotty, 05-24-2003 20:17:28
I have a replaced Ford -V8- with the following numbers stamped on the passenger side behind the dip stick rod holder on the front of the block block.
B A Star
05-26-2003 21:59:02
The casting numbers that you listed are for a crankcase used in a 66 Oliver. There should be a casting date on the L. H. side of the crankcase near where you found the other numbers. Those numbers would tell us the date the casting was made, thus the year of the tractor.
