Carb icing on 1600 gas
Roger
04-21-1999 15:05:52
I'm experiencing icing of the carb which shows up as white frost on the flange that bolts to the intake ,about an inch each way from the flange.The tractor will only stay running with the choke half wayor more on.I've tried HEET to no avail.I have a sediment bowl on the outlet of the gas tank,but I don't have an in line filter.Would this help?
Roger
04-23-1999 13:52:35
 Re: Carb icing on 1600 gas in reply to Roger, 04-21-1999 15:05:52
Thanks everybody for your advice.Having to keep the 1600 running for Dad is kinda a chore,butit keeps him from abusing my poor littlemint condition,2100hr 1550.
Bob M
04-23-1999 05:06:35
I have a 1600 Industrial (gas) - it's plagued with the same carb icing problem you describe. Seems worst in damp weather when the temperature is 35 - 45 deg or so. Here's a few things I've found which help:
1 - Make sure the carburetor is properly adjusted for warm, dry weather operation - especially the idle mixture adj.
2 - Before using the tractor, start it and run at fast idle (1,200 RPM) for 5 minutes or, or until the carb is nicely frosted outside. Now shut it off and wait about 5 minutes until heat soaks from the exhaust manifold and melts the frost. (If there's any breeze, position the tractor so the manifold side is out of the wind.) After the frost is gone, tractor should start/run fine.
3 - Until the engine is fully warmed up, run the tractor in a lower gear/higher RPM than normal - especially if you're working a light load.
4 - Use fresh gas! (Not gas that's been sitting around for 6 months...) I've found a bottle or two of dry gas in each tank of gas helps too.
Mike
04-22-1999 13:35:33
 Re: Re: Carb icing on 1600 gas in reply to Jack in NB, 04-22-1999 03:23:08
Hey now this is the kind of answer we need. Good Job. Now if you guys can figure out how to get some from the exhaust manifold to the carb he could get the problem fixed.
mm
04-21-1999 15:39:12
You need to get some heat to it from the exhaust manifold.
mike
04-21-1999 19:07:35
 Re: Re: Carb icing on 1600 gas in reply to mm, 04-21-1999 15:39:12
If mm is going to offer coments with no viable solution, why doesn't he keep his nose under his own hood?
