S55,550,2-44 ?
DuaneWKKC
05-23-2003 11:16:30
Thinking of selling my 1650D and getting a smaller tractor. Just courious what the main differences are between the 3 models of the same tractor( s55,550 and 2-44 white). Mostly interested in the hydraulics as I will occasionally need 2 scv's. Also, will these tractors handle the weight of a 88" flail mower (approx 1,600 lbs). Thanks for any feedback.
DuaneW
D13
05-24-2003 04:42:15
 Re: s55,550,2-44 ? in reply to DuaneWKKC, 05-23-2003 11:16:30
They came with only 1 SCV. The 2-44 is a 550 with the compression turned up. Very reliable. It will choke on an 88" flail mower - you'll be running in lowe gear in any type of thick material.
Will it pick up 1,600#? Maybe, but you'll have to add 500# to the front, at least. Maybe buy one with a loader and keep some big rocks handy. I sure wouldn't make a practice of it. THese tractors only weigh 3800# or so, asking it to pick half its own weight up is a risk, and it sure won't like it. Front end will come off the ground and you'll be looking for axle bearings soon.
Frank Dodson
05-23-2003 19:38:02
I would go for the 550 since there were several improvements over the S55. The engine increased from 144ci to 155 ci., compression ratios were increased and improvements were made to the hydralics. The 550 had at least 8-10 more hp. I think the 2-44 was the industrial version of the 550. It was painted yellow with a 4 speed shuttle shift. I think it was introduced as the White-Oliver 2-44.
Larry from MD
05-23-2003 12:51:22
Finding those tractors with remotes is harder than you might think.I used to use a S55 with a 6ft flail mower and would not recomend going any bigger.It lifted it fine as the wieght was close to the wheels.At 34hp you had to drive slow in grass with any size to it.If you find remotes the output is lower preasure and lower flow than the 1650.
