Repower 2255
Jim Meade
05-22-2003 07:21:47
What are the repower options on a 2255? The 3150 Cat is starting to smoke a lot. I can live with it, but if I were to repower, I'd prefer something with more lugging power and something not so noisy, if possible. Are there any six cylinder engines that will drop in without too much trouble? No MM big bores, please!
Adam Suess
05-22-2003 20:58:51
 Re: Repower 2255 in reply to Jim Meade, 05-22-2003 07:21:47
I'm not sure what would work good for a repower. The way the tub is on a 2255 would make it tuff to fit any thing other than the cat or a V-8 configuration. Maybe a v-8 perkins I have one in my 9720 combine and has all kinds of power. Or the 3208. Could look at a IHC 6.9 or 7.3 but you'd have to have the pump redone for industral work. I have a ford with the 6.9 diesel very good so far and rated the same flywheel hp as my 3150. If my 2255 ever goes bad I think I'll fix the 3150. Other wise you could try and mate the front of a 2150 or even a 2-135 to the 2255 and run the 478 engine. I have a 2-135 with that engene pretty good but likes fuel. Used in many military trucks and available relitivly cheap from some surplus dealers. your 3150 using oil?
D13
05-24-2003 04:36:41
 Re: Re: Repower 2255 in reply to Adam Suess, 05-22-2003 20:58:51
3208 cat was standard in the late 2255's. I've heard you need to pay attention to replacement motor location of accessories for underhood clearance.
Tell you what, I'll pay you $1500 and take it off your hands. LOL. :')
m kuhns
05-24-2003 08:34:53
 Re: Re: Re: Repower 2255 in reply to D13, 05-24-2003 04:36:41
Don't laugh, we bought our 2255 with the 3208 for $4,000. We had it for 6 years now. It has been a great hard working tractor. We had to put in PTO clutches in it last year, and a clutch in it. That is all we basically did to it. It has hauled over 130 loads of manure a year with our 5,000 gallon tanker. IT is mainly all road hauling up and down hills about 2 miles each direction. It goes up just about any hill in 5th direct. Total weight is 80k with tractor and loaded tanker weight combined. How many tractors can you buy for this little and do this kind of work with? I'd stick with the old 3208 Cat. Lots of potential for lots of POWER if needed. I wouldn't put in a perkins. Parts are way too expensive for the v-8.
Ollie
05-24-2003 09:14:22
 Re: Re: Re: Re: Repower 2255 in reply to m kuhns, 05-24-2003 08:34:53
$4,000? Has to be the deal of the century. A new one would easily be 10 times that. Good for you!
