Ixb-3 generator charging problems
Glen
05-21-2003 18:42:00
Had the original 6 volt generator converted to 12 volt. Hooked up to a 12 voltN/P regulator, hooked it up field terminal of generator to (F) of the regulator, hooked Armature of generator to (A) of regulator, Ran wire from (BAT) of regulator to negative Battery side of switch, then connected Positive side of battery terminal which I grounded to tractor.Results battery did not charge, changed battery around.Positive to neg, neg to positive, battery not charging, everthing brand new. Does anyone know what I must do in order to make the generator charge the battery?????Help
Larry from MD
05-22-2003 09:27:09
 Re: ixb-3 generator charging problems in reply to Glen, 05-21-2003 18:42:00
The way you had it hooked first was correct.When all the parts are put on new then the system needs to be polarized to start working.Use a small wire and touch the ends on the a and b posts on the regular togather momentarily While the engine is running.
