Coop E-3
Randy
05-19-2003 19:08:47
Help needed. Where is the serial number located? What is a 4B153 engine? This is the only Coop I ever saw.
Phil Heisey-Harleysville,
05-23-2003 03:18:17
 Re: Coop E-3 in reply to Randy, 05-19-2003 19:08:47
Randy,
I have many new and used Co-op/Cockshutt parts on inventory. I specialize in ONLY Cockshutt built Co-op/Cockshutt. I have all the engine rebuild parts too!!!
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
Irv
05-20-2003 17:07:14
I have a bunch of these so contact me by email and I'll help you with all you need! Irv [email protected]
Randy
05-21-2003 14:20:36
 Re: Re: Coop E-3 in reply to Irv , 05-20-2003 17:07:14
Irv, thanks for the reply on my E-3.Where do I locate the serial number? Is this a Buda engine(4B153)? The tractor has been outside for years but it is in good condition,straight tin and about 90 to 95% complete. Engine was running when parked. I am considering a rebuild. Front wheels are missing, what will fit and what size? Grill inserts are gone. Thanks Randy in SC
Frank
05-19-2003 20:39:56
check out www.cockshut.com for more info on the cockshutt/co-op 30
Earl
05-19-2003 19:57:46
the serial number is located on the frame on the right hand side of tractor stamped in the top of the frame where the frame is a little thicker, about center of the engine, it should start with a 30 then a space then the number, they are same tractor as a cockshutt 30, the 4b153 is a 153 cubic inch 4 cylinder buda engine,
Earl
05-21-2003 14:30:42
 Re: Re: Coop E-3 in reply to Earl, 05-19-2003 19:57:46
Thanks Earl for the info. Randy
