1900
lucky1468
05-19-2003 18:20:38
our 1900 serial#117-176-982 all hydralic oil ends up in transmission after running about 15 min.
ned
05-20-2003 18:41:18
 Re: 1900 in reply to lucky1468, 05-19-2003 18:20:38
my 1850 lost fluid last year but pumped it all out in under a minute (8 gal per minute) out of the front seal, and it did go into the transmission (could also be a hole in the pan if one of the pinions go out it can ripe a big hole in it) my pan had a pin hole where the three point ram rubed and wore a hole had to replace. can find after market pumps between $350.00 and $450.00 is a big job especialy with a cab.
WFE
05-19-2003 22:21:33
Leaks only when running? Could likely be the front seal of hydraulic pump. Rebuilt pump should take care of it.
