1650 mfd vs 1655 mfd?
Woodbeef
05-19-2003 15:02:23
Which one is a better tractor and why?
Leo
05-19-2003 18:22:12
 Re: 1650 mfd vs 1655 mfd? in reply to Woodbeef, 05-19-2003 15:02:23
Both are good, and are arguably the 2 best ever built by Oliver. 1655's are "precision" machines. 1650fwa may be a little rare'r.
Dean Barker
05-19-2003 18:58:51
 Re: Re: 1650 mfd vs 1655 mfd? in reply to Leo, 05-19-2003 18:22:12
The mfd are the same in both tractors. I think the early 1650's had precombustion chamber diesel engines while the late ones had direct injection diesels. The early 1650's had only the two speed hydrapower powershift. The late 1650's and the early 1655 were basically the same tractor with the 3 speed over-under powershift and the direct injection engine. The later 1655 tractors had a different fuel filter. Both very good tractors.
Jim Meade
05-22-2003 07:12:52
 Re: Re: Re: 1650 mfd vs 1655 mfd? in reply to Dean Barker, 05-19-2003 18:58:51
Did both have the same pump, or was the 55 hydraulic pump different? Did the 1655 have a closed center pump like the other '55 series?
Shep VA
05-22-2003 08:23:19
 Re: Re: Re: Re: 1650 mfd vs 1655 mfd? in reply to Jim Meade, 05-22-2003 07:12:52
No the 1655 has a open center system just like the 1650 does. In the 55 series the 1555 and the 1655 retained the open center hydraulics while the 1755 1855 and on up changed to the closed center system. There are some minor differences in the hydraulic systems between the 1650 and 1655 but for the most part they work the same way.
