Model of trailer plow
Ty
05-18-2003 18:58:03
I just got a 3-14 on rubber. Hyd. lift, full size rear tire, coulters. 6 bolt hubs. Is it possible that they made a add on bottom. The land wheel is in line with the 3rd bottom.
B A Star
05-18-2003 20:48:35
 Re: Model of trailer plow in reply to Ty, 05-18-2003 18:58:03
From the description that you gave, you have a 4240 plow that is convertable from a 2 btm to a 3 btm. A 4240 plow has the beams for the first two bottoms that go all the way to the front, with the land wheel running in front of the third bottom if so equipped. A 4340 plow has three beams for the first three bottoms going to the front and the land wheel runs in front of the fourth bottom (is wider between land and furrow wheels). 4340 is convertible from 3 to 4 btms.
