Oliver What?!
SCOTTY
05-18-2003 13:27:31
I have a Oliver tractor, that I'm sure of but that's about it. The old guy I got it from said he thought it was made in 1954 but didn't know the model . The serial # plate has been knocked off and lost plus the front sheet metal is lost in the honey suckle patch that the tractor came from so I won't be able to find that until the fall when the honeysuckle dies off so I know nothing about this animal. I think it may be a 550 is there any to tell? Thanks for any help Scotty
luke
05-19-2003 16:57:39
 Re: Oliver What?! in reply to SCOTTY, 05-18-2003 13:27:31
they dident make a 550 in 1954
Scotty
05-20-2003 19:19:24
 Re: Re: Oliver What?! in reply to luke, 05-19-2003 16:57:39
Thanks for your help.I am not sure of the year but I'm still searching Thanks for your time Scotty
Max
05-19-2003 15:36:06
Is it tricycle or wide front? What about tire size? From the other responses it sounds like a Super 55, especially when you said the gearshift was on the left side. If it is a 1954 model could not be a 550, they didn't make those until 1958. Hope this might help.
Scotty
05-20-2003 19:13:35
 Re: Re: Oliver What?! in reply to Max, 05-19-2003 15:36:06
Thanks Max, the tractor has a wide front and the tire sizes I have are Rear 14-26 front 6.00-16 the gear shift is on the left side under the seat, that I'm sure of.I was told it was a 1954 but I'm not sure what year it is.Thanks for your time and help, Scotty
gary
05-19-2003 05:31:30
If it's a 550 there will be 4 holes under the bull gear area to mount a brk for the drawbar. The 55's had a horseshoe shaped brk. which bolts on with the axle housing bolts except for a few of the last ones had the 550 brks.
Scotty
05-20-2003 19:49:43
 Re: Re: Oliver What?! in reply to gary, 05-19-2003 05:31:30
Gary, Thanks for ALL the help. I have the horse shoe shaped bracket that bolts on the axle houseings for sure and the casting # I gave you 1E-500A came off the front frame section for sure, so it's looking more like a 55 all the time.Sounds like you are the OLIVER man for sure..Thanks for all your time and help, Scotty
SCOTTY
05-19-2003 09:53:41
Gary, Thanks for the info. I'm home now for lunch as soon as I get home tonight I will check it out and let you know what I find.I work at a John Deere dealer ship but I'm being treated like a red headed step-chid because I bought this Oliver,I keep telling them it's still green but they still want to chunk rocks at me, but I like the old tractor, just can't figure out what I got. Thanks for your time, Scotty
Dave J in WI
05-19-2003 10:35:39
 Re: Re: Re: Oliver What?! in reply to SCOTTY, 05-19-2003 09:53:41
Aaaaah, don't worry about the guys at work. They are just jealous that you got a better tractor than they sell!
Scotty
05-20-2003 18:58:30
 Re: Re: Re: Re: Oliver What?! in reply to Dave J in WI, 05-19-2003 10:35:39
Thanks Dave J , I'm going to use that line tomorrow but I'm going to where my hard hat cause there is more of them then me.But it's funny,those guy's chunk'n rocks will be the first to ask to use it!!!!! !!!! Thanks, Scotty
Larry from MD
05-18-2003 14:15:21
Yes many of large castings have have dates on the bottem of the tractor.They are aranged like this DAY-MONTH-YEAR.As an example 20-5-59 would be may 20 in 1959.Theres not much differanxe in a S55 and a 550 so find a year and look at some pictures on the left of this page for an id.
SCOTTY
05-18-2003 19:14:12
 Re: Re: Oliver What?! in reply to Larry from MD, 05-18-2003 14:15:21
Larry, Thanks for the help. The onley numbers I could find on the bottom side of the tractor are on the front frame section 1E 500a the next set of # I found are on the trans. 1E 599a the last set of # I found are worn almost off I can't read but the first 3 # and they are 928 can't read the rest of the # wore off but they are in between 2 drain plugs toward the back of the tractor.I don't know if this will help any but the gear shift is on the left under the seat and I do know it has a American Bosh injection pump.. The tractor has been well presivered in oil, grease and dirt,going to steam clean the tractor soon maybe I'll find some more # Thank you for your time Scotty
Gary
05-19-2003 18:02:53
 Re: Re: Re: Oliver What?! in reply to SCOTTY, 05-18-2003 19:14:12
The 1E-500-a front frame was used on S-55 from #6503-39921
