Need AC before it gets too hot
doc
05-16-2003 19:01:05
My cab came with the AC unit on top and hoses but no compressor. I have a chance at the entire unit off of a GM car. Can the compressor be adapted to the lines and recharged, or am I blowing hot air?
Kevin
05-16-2003 20:15:25
 Re: Need AC before it gets too hot in reply to doc, 05-16-2003 19:01:05
No reason it can't be installed, although the GM system should be a newer one using R134A, R12 is getting hard to find!
Don-WI
05-18-2003 20:10:31
 Re: Re: Need AC before it gets too hot in reply to Kevin, 05-16-2003 20:15:25
If you do, and you can, put R 134 in right away. R 12 is almost $50 a lb., where the R 134 is a heckuvalot cheaper than that, I think about $5, if not less.
Donovan from Wisconsin
doc
05-19-2003 05:24:45
 Re: Re: Re: Need AC before it gets too hot in reply to Don-WI, 05-18-2003 20:10:31
I see that. Waiting to see what the reserve is. I have three or four cans myself. :)
