Super 55 PTO Clutch
BigPapa
05-16-2003 11:14:21
Well, I finally got my steering rebuilt and all my fluids flushed and changed so I went to do a little bush-hogging yesterday. It's some pretty thick fescue and a bunch of thistles and I haven't sharpened the blades on my old 6' bush-hog yet, but about 10' into my first cut my PTO qiut turning. Lifted it up and she started turning again. Evidently my clutch is slipping pretty bad. It did OK as long as I kept it about 14" off the ground, full throttle, and in 1st gear, but any lower or any faster and she'd bog. Engine speed never changed. Do I need to try adjusting it or just go straight for the rebuild? I understand that I'll have to split the tractor to do this, is there anything else I need to do while I'm in there? Any advice on where to get the parts? Thanks !
Larry from MD
05-16-2003 12:35:40
 Re: Super 55 PTO Clutch in reply to BigPapa, 05-16-2003 11:14:21
Yes try ajusting it first,remove the plate under the clutch houseing and useing a long screwdriver push in the button and turn the ring with noches.
Steve
05-19-2003 16:27:59
 Re: Re: Re: Super 55 PTO Clutch in reply to jake, 05-17-2003 08:59:34
You need to install a overrun clutch on your PTO out-put shaft on the tractor. This will save your clutch a lot of wear. You may need to shorten your bush hog PTO shaft.
