Oliver plow shares
Dax
05-13-2003 19:03:25
Need 2 plow shares for a 2 bottom Oliver plow. 14inch bottoms, p/n R-NC25-14 Oliver Radex
Geoffrey in KS
05-15-2003 16:57:43
 Re: Oliver plow shares in reply to Dax, 05-13-2003 19:03:25
The shares available all have one too many holes in them and to me they don't look right. I have always found decent used ones and then don't use the plow enough to wear them out.
ed
05-14-2003 13:05:57
I believe those shares are available at Tractor Supply Stores or TSC.com
ShepFL
05-15-2003 12:58:03
 Re: Re: Oliver plow shares in reply to ed, 05-14-2003 13:05:57
Good luck and I hope you have a good TSC!!
I waited six months to get some shins for a 3 btm 4340 plow. Never showed up so I went and got my $$ back. I have found that my local TSC has very, very little experience with ag maintenance. I see this as secondary to lawn mowers, corrals and feed. I am disappointed to say the least.
DKaiser
05-16-2003 21:40:32
 Re: Re: Re: Oliver plow shares in reply to ShepFL, 05-15-2003 12:58:03
You can get shins and shares for some of the olilver plows, HOWEVER I don't think they will fit that old of a plow. Your best bet is to find new-old stock or good used parts. I would beware though that we took apart some 225 bottoms on a 4-14 and the bolts used on the bottoms were very hard to find. They are different than what is used on the newer plows. I guess if you weren't fussy on looks you could probably make something work. I think we did try seeing how a newer set of lays and shins would fit on an older bottom and I'm not sure if the holes lined up or not.
