770 clutch replacement
KMcmMillsn
05-07-2003 13:00:19
How big of a job to replace clutch/pressure plate. Do you have to split the tractor or can it be done by sliding the bell housing back from the motor? Is there a better way?? Thanks in advance for the help!! KMcMillan
Steve
05-07-2003 18:33:50
 Re: 770 clutch replacement in reply to KMcmMillsn, 05-07-2003 13:00:19
KM,
Does your 770 have a power booster? Does it have a belt pulley? Depending if you do or not, you may need to pull the motor out. No need to split the frame. Let me know.
KMcMillan
05-09-2003 06:47:02
 Re: Re: 770 clutch replacement in reply to Steve, 05-07-2003 18:33:50
No belt pully, no pwoer booster.
Steve
05-09-2003 20:42:49
 Re: Re: Re: 770 clutch replacement in reply to KMcMillan, 05-09-2003 06:47:02
K,
You are lucky! You can just unbolt the coupler and move the bell housing rearward. No need to pull the motor.
K McMillan
05-12-2003 12:00:03
 Re: Re: Re: Re: 770 clutch replacement in reply to Steve, 05-09-2003 20:42:49
Thanks for the info; it is much appreciated!!KM
