1850 seats
Chuck
05-03-2003 05:59:25
For years I've been sitting on seats that seem like wood benchs on my 1850's. Now that I'm older I'd like to find more comfortable ones. Yards seem to be all out of them as they get picked up, it seems. Any thoughts or help as to where I could get some would be much appreciated. Thanks Chuck
jps
05-07-2003 14:46:30
 Re: 1850 seats in reply to Chuck, 05-03-2003 05:59:25
Replaced seat cushion on my 1850, seem like around $60.Have original seat. I think some outfit in Minn.does it. Boought at my White dealer! Can get the ph.# if you like.Also saw same co. at farm shows in winter at Vermilion,SD jps
Rick
05-05-2003 17:11:53
Do you still have the original suspension on the tractor ? Toll Free 1-866-264-9720
Sam M
05-05-2003 07:37:41
I purchased what I think they called a Deluxe Comfort Tractor seat from Quality Tractor Supply ( I believe it used to be C&T Tractor) that bolted right up to deluxe suspension on my 1850 tractor . The seat has a metal frame , high back and moveable arm rests and is really comfortable . The price was a little over $200 which is high but when you consider the seat is one part of the tractor you use every time you start it up and the seat can make the difference between whether you sit for 4 hours or 8 hours and how much of that you spend in pain , I thought the price was worth it . I have since put a similar seat on my 1855 .
dwm
05-05-2003 06:45:28
You might try Speer Cushion Company, they advertise in the antique magazines. Don't have any experience with them, but they may be less expensive than going to Agco. 800-525-8156 or www.speercushion.com
Chuck
05-06-2003 06:17:23
 Re: Re: 1850 seats in reply to dwm, 05-05-2003 06:45:28
Thanks a lot you guys. Now it looks like I will have something comfortable to sit on this fall.
Chuck
Ollie
05-03-2003 08:27:02
I had an upholstery shop rebuild the seat pads on my 1650 using high density polyurethane foam. It looks OEM but is far more comfortable to my old and large bottom. I have the pan type seat for which replacement cushions are not available. If you have the chair type seat, any AGCO dealer can sell you OEM looking replacements pads.
If that doesn�t float your boat, Northern Hydraulics sells dozens of different type of ag seats but you may have to devise some type of special mount to fit it to your tractor.
ol George
05-03-2003 18:48:53
 Re: Re: 1850 seats in reply to Ollie, 05-03-2003 08:27:02
We mounted a universal seat on an 1800 by using channel iron and drilling four holes. It now sits on a friends 1655 really looks nice and rides a bunch better.
