Hydralic needle
joe
04-28-2003 06:27:36
Under the seat of my 1850D it is leaking fluid. It is coming out of a boltwhich has a needle in the bolt. Should there be a o-ring around this and is this hydralic fluid. Also my direct drive on my under over sometimes comes out is there a adjustment for this Thank You
jps
05-07-2003 15:37:25
 Re: hydralic needle in reply to joe, 04-28-2003 06:27:36
Seems like direct drive is when the one way bearing is used. Someone should know more than I do!! jps
GregR
04-29-2003 04:19:23
On my Oliver 1650, I fixed it by putting a copper washer under a new nut that has the nylon insert (lock nut with plastic in it). Mine hasn't leaked anymore.
No info for the over/under.
Greg
Larry from MD
04-28-2003 15:44:47
Those bolts leak sometimes.Some had copper washers under the nut but the newer ones had a washer with an oring inside it.Might be time to change the oil and filter in your hydro-power.
