Oliver 1650 Engine
Eric Jas
04-27-2003 20:02:22
I've got two Oliver 1650 gas tractors, one with a loader. One of the tractors has a bad engine and I was wondering if anyone has put a diesel engine in one of these tractors? If so, where can I get one and how much modifying will have to be done?
E J
04-30-2003 08:42:21
 Re: Oliver 1650 Engine in reply to Eric Jas, 04-27-2003 20:02:22
I have a 310 1955 engine in my 1650 you have to use the short water pump & pulleys it fits.
Craig
04-30-2003 09:19:35
 Re: Re: Oliver 1650 Engine in reply to E J, 04-30-2003 08:42:21
EJ, was the water pump the only mod. needed to intsall a 310 in your 1650?
Craig
dwm
04-28-2003 08:03:32
Bad engine meaning worn rings and bearings or bigger problems? Just my 2 cents, but a 1650 gas for a chore tractor is hard to beat as they will start no matter what. I would guess a 1650 diesel will end up being more money if all you need is an overhaul on the gasser, and take it from experience, the diesel will not start in the winter without being plugged in, ether, or being in a warm shop. Good luck however you go.
j meyer
04-29-2003 08:03:01
 Re: Re: Oliver 1650 Engine in reply to dwm, 04-28-2003 08:03:32
My exact thoughts, dwm. The 1650 gas is an excellent tractor.
Ollie
04-28-2003 11:53:13
As a 1650G owner, you took the words right out of my mouth!
Farmer in the Dells (WI)
04-27-2003 23:08:21
Check with Shep VA. Believe he has done several conversions and replacements. I know he won't mind putting his link out here, there is alot of good information there and he is happy to share it.
Don-WI
04-27-2003 20:32:10
Shouldn't be that hard, there really aren't many other components other than what would come on an engine that's complete. Make sure there isn't any gas in the tank as to not contaminate the deisel(and cause problems). The engine should just bolt right in place, as I'm almost positive they used the same block for both, just a few different internals like crank and pistons. Try to get the newer deisel, with direct injection, or if possible step up to maybe a 55 series engine or a 310. (these are very durable engines if built right) If you go to a larger size engine, it might be a little longer, so you may have do do something with the radiator. Over all, a very doable project and won't be a very bad tractor when you're done.
Donovan from Wisconsin
