Super 55 Steering Box
BigPapa
04-25-2003 07:19:16
Well, I took the steering box apart to rebuild it and found that someone had rigged it up with the wrong bearings on the steering shaft. They weren't even close to fitting the shaft so that's where my steering play was. I've got it all ready to go back together and thought that one of you could give me some tips on reassembly so I don't have to tear it apart again. My question involves putting the pitman arm shafts and the worm gear back in time. I marked the arms and the shafts so I know how they go. The wheels are facing straight ahead. Thanks for the help!
jake
04-25-2003 08:25:15
 Re: Super 55 Steering Box in reply to BigPapa, 04-25-2003 07:19:16
Timing the box is under archives #11. Center of travel[wheel] is 2 5/8 turns. The pitman arms have splines in 4 sections 90-180-270-360 so cant't be wrong if gears timed properly. Search archives as "55 steering box". If any problem just call. Jake
